White smoke
Old 06-13-02, 12:23 PM
fl-lawn
White smoke
I have a b & S 11 hp on my rider mower. I put a new short block in it about 200 hours ago(old one locked up-no oil) and it run fine for 100 hours or so. Then it started blowing white smoke but still run ok, but lately it has been getting worse. Ever time I start it up it smokes like crazy and lacking a little power(it got the right amount of oil in it),soI thought it might be a fuel problem so I replaced the carb with a new one. No difference, still smokes.
So what next ?????????
Head gasket
Valves
Rings
Help Thanks Chris !!
Old 06-13-02, 09:52 PM
cheese's Avatar
Received 22 Votes on 19 Posts
If it's not too full of oil, then it may be the pcv valve. If that is good, I would suspect ring failure. If you have a cast iron sleeved engine, a ring set may solve your problem. If your engine has an aluminum cylinder, it may be scored.
Old 06-16-02, 12:13 AM
bwiesner
When you replaced the short block did you check the throttle and choke shafts to make sure they weren't worn out. If they were the engine would suck dirt right past them and ruin your new block. Later Butch
