Lawn Tractor Question
Old 06-15-02, 10:36 AM
fly944
john deere
Hay guys I have a john deere tractor hydro 175 w/a fc 420 v engine that will not turn over. Batt. is good and i here a click when switch is turned. Starter is good and solenoid is ok. I think I am having a problem w/ one of the safety cut off switches. I don't have a wiring diagram and don't know where all the switches are. If someone could tell me where they are or send me a diagram or tell me how to bypass these switches I would appreciate it.
Thanks
Old 06-15-02, 12:37 PM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello: fly944
I would not suggest nor will I instruct anyone how to bypass safety devices. However, if you use an ohm/volt meter and or a continuity checking light or device, it's very possible to locate a defective or inoperative safety device or any common switch.
In the case your describing, the desription indicates current is in fact getting to the starter solenoid based upon the clicking sound. This being the case, check for rusted and or corroded terminal connections, loose connections, frayed or corroded wires etc.
There is always the possibility the solenoid is defective and or the starter motor. Removal of the suspected parts and having them tested at any local dealers retail store or small engine repair shop may disclose the source of the problem.
Most likely I have not covered all of the potential problems. The other resident small engine service and repair professionals may offer additional suggestions, advice & help. Check back several times for additional replies.
Read the other topic postings and replies offered on this topic of engines that fail to start and the ARCHIVES, within this forum, for additional help & information on this topic.
If you need further assistance, use the REPLY button to add any additional information or questions, etc. Using this method also moves the topic back up to the top of the list automatically.
Regards and Good Luck, Small Engine Forum Host & Moderator
Tom_Bart.....TCB4U2B2B.....Company Enterprises.
Fast...Fair...Friendly & Highly Efficient Services....
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
