Engine Starting Problem
Spanky's Avatar
06-16-02, 04:36 PM   #1
Spanky
tiller
Hi I have a small Sears Craftsman 1.6 Hp tiller/Cultivator pull start. It will not start new plug, fresh fuel & oil mixure. what else could be. I check there is no spark or very faint spark barely see it.Please help.
Sal
Sharp Advice's Avatar
Admin Emeritus
CAL
06-16-02, 06:03 PM   #2
Hello: Sal
Even though there may be what seems like a tiny spark, for the time being I would suggest you verify if the engine will start.
Simply remove the plug, add a few drops of fuel directly into the plug hole and reinstall the spark plug. Attempt to start the engine as you normally would.
If the engine starts, runs and dies quickly, the carb either may not be getting fuel or the carb is gummed up. You may need to repeat this procedure once or twice if the engine fails to start or simply crank it a few times with the choke off.
If the engine continues to not show any signs of attempting to start, try another spark plug. Remove the fuel line hose from the carb and test for fuel flow. The kill switch may be tested for continuity. Also check for rusted or corroded terminals, etc.
The idea here is to find the problem without first suspecting the ignition system to be the problem. What appears to be a tiny spark or weak spark may or may not be correct.
The other resident small engine service and repair professionals may offer additional suggestions, advice & help. Check back several times for additional replies.
Read the other postings and replies offered on this topic of engines that fail to start and the ARCHIVES, within this forum, for additional help & information on this topic.
If you need further assistance, use the REPLY button to add any additional information or questions, etc. Using this method also moves the topic back up to the top of the list automatically.
Regards and Good Luck, Small Engine Forum Host & Moderator
Tom_Bart.....TCB4U2B2B.....Company Enterprises.
Fast...Fair...Friendly & Highly Efficient Services....
"Accurate Power Equipment Company"
