Toro Mower Starting Problem
Old 06-22-02, 11:30 PM
Davidmower
I have a Toro model # 20448 that I purchased in 1998. After priming it will start, but will immediately shut off. If I keep priming it will continue to run. I have checked the fuel flow, that is fine. I have sprayed gumout all over the carb but that hasn't helped. I have tried cleaning all the holes I could find in the bowl screw, and the carb body. Nothing seems to make it work. I have taken it into the dealer for this several times, they always tell me I have water in my gas. How can I always have water in the gas? The gas I have in the tank right now I just got from the gas station. It still won't work.
Thank you for your help.
Old 06-23-02, 02:44 AM
cheese's Avatar
Received 22 Votes on 19 Posts
You seem to be having trouble with the carburetor. You may need to remove it and clean it well. It sounds like one of the tiny holes in your bowl screw is stopped up. Look closely, there are tiny ones that are hard to see if they are clogged. What brand engine is on it? And HP?
Old 06-23-02, 09:17 PM
Davidmower
I took the carb off, cleaned it good. Now it works. Thanks
Old 06-24-02, 12:28 AM
cheese's Avatar
Anytime ....good job!
