Pull a Pulley
superachiever's Avatar
06-30-02, 12:13 PM   #1
superachiever
Pull a Pulley
I have a Homelite (Simplicity) Tractor that I'm replacing the 10 HP Briggs and Stratton Engine. I need to remove the pulley's off drive shaft (under the tractor). The pulley's have a hex screw that I have removed...this screw went into the key on the shaft. What tool do I need to pull the pulley? Where can I find this tool? Thanks!
troyrhoades's Avatar
06-30-02, 12:20 PM   #2
troyrhoades
What you need is a 2 or 3 jaw pulley puller "either will work" and you can get them at any part's store.......... you wont need a expensive one for this task.
cheese's Avatar
GA
06-30-02, 10:37 PM   #3
Autozone should have one for rent. If it is a stamped metal pulley, be careful, as a puller can bend one easily. Make sure there is not a bolt in the center of the pulley, in the hole where the end of the crankshaft is.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
