Won't start
Spanky's Avatar
06-30-02, 08:55 PM   #1
Spanky
Won't start
My riding mowing will start. it start for a couple of days ago but it will not. It is trying to start it pops a couple of time. it is getting fuel the bowl on the carb is working alright.But everytime I try to start it I draw the battery down please help.
Sal
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
06-30-02, 09:19 PM   #2
Hello: Spanky
Trying to better understand the problem description your describing. From what I gather, the engine use to start a few days ago but won't now?
The poping sound could be ignition timing. If the blade or blades struck an immoveable object, it's possible the shear pin securing the flywheel to the engine shaft is slightly bent.
If this is the case, the engines timing will be off, causing the problem described.
Another possibilty could be fuel related. Just because the fuel bowl has fuel in it, does not mean sufficient fuel is passing thru the carb into the engine.
If this is the case, the carb must be carefully removed, disassembled, cleaned and cleared out of any gum or varnish deposits. Then correctly reassembled, most likely using a carb rebuild kit.
Most likely I have not covered all of the potential possibilities. The other resident small engine service and repair professionals may offer additional suggestions, advice & help.
Check back on your topic several times for additional replies.
Read the other postings and replies offered on this topic of engines in the RECENT & ARCHIVES postings, within this forum, for additional help & information on this topic.
If you need further assistance, use the REPLY button to add any additional information or ask additional questions, etc. Using this method also moves the topic back up to the top of the list automatically.
Regards and Good Luck, Small Engine Forum Host & Moderator
Tom_Bart.....TCB4U2B2B.....Company Enterprises.
Fast...Fair...Friendly & Highly Efficient Services....
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
cheese's Avatar
GA
06-30-02, 10:49 PM   #3
What kind of engine is it? What HP, model #, etc...
Your carb could be leaking fuel into the cylinder, wetting the plug, or any of the things Tom mentioned.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
