what could be wrong?
Old 07-09-02, 07:39 PM
ringoryan8
Cool what could be wrong?
i got a free mower and i wanted to know what the possibilities of problems are that could be wrong. (does that sound right?)
The pull starter is hard to pull( the piston may have seized) what are the signs of a siezed piston and what are other things that could have gone wrong with it and what are the signs?
thanks for your help
Old 07-09-02, 08:29 PM
cheese's Avatar
Hello ringoryan8!
Make sure the safety bar cable is disengaging the engine brake....if equipped. If it isn't, that is your problem. If it is, Remove the spark plug, try to turn the engine by the blade. If it doesn't budge, it is siezed. Also if it is out of oil, it is a pretty good indication that it is siezed too.
Old 07-09-02, 08:37 PM
ringoryan8
at first it wouldnt budge but now it does, i guess it may have been seized. what do i need to replace?
Old 07-09-02, 08:54 PM
cheese's Avatar
You may not need to replace anything. What kind of mower is it? You might try starting it, and go from there to find out what needs repair.
Old 07-09-02, 09:08 PM
ringoryan8
its really hard to pull though. I have a california snapper. briggs 3 1/2 hp.
Old 07-09-02, 09:18 PM
cheese's Avatar
Was it out of oil? Did you check the safety bar cable?
Old 07-09-02, 09:20 PM
ringoryan8
it had some oil, i'll check the safety bar cable and respond tomorrow
Old 07-09-02, 09:21 PM
J A Boggan
The first thing I would do is pull the head off. You can inspect the cylinder (for scouring) and also if the valves are working properly and what condition their in.
Old 07-09-02, 09:30 PM
cheese's Avatar
That is a good way to get an idea of what kind of shape the engine is in, but to find out whether the hard-to-turn condition is internal, or external, the easy things should be checked first.
