carb
Old 07-15-02, 01:17 PM
Spanky
carb
my lawn tractor has a 11Hp B&S Engine. I just rebuld the carbnow when i try to start it keep's pop pop pop it seen it is trying to start but it won't. Tha popping sound like a gun going off no matter what I try to do Pleaseeeeeeeeeeee Help Iam about to take this tractor and run it over with my truck. the carb has all new parts on it. Only thing Iam not to sure about was the float I was very careful when I put it back together so again please help because grass is about 8" tall an my wife is about to kick my butt.
Sal
Old 07-15-02, 09:48 PM
cheese's Avatar
Change the spark plug. It sounds like it got fouled with wet gas. The float should be set as follows: Remove the carb, take off the bowl, turn the carb upside down. The float should be paralell to the carburetor. If it needs adjustment, bend the tab that holds the needle up or down, a little at a time, as needed. Unless this is the newer type carb with the plastic float. Then you cannot adjust it.
