2 Cycle Carb Question
weed eater carb
I have a Craftsman weed eater with the Walbro carb. What are the intitial settings on the 2 carb. adj. screws? Thank You.
Received 7 Upvotes
Hello: tnpops
I would suggest you start with the low {L} speed screw set outwards 1 turn and the high {H} speed screw 1 1/2 turns.
This should get the engine running. The final setting of the low {L} speed screw will be about 3/4 to 1 turn outwards.
The high {H} speed screw about 1 to 1 1/2 turns outwards.
Much of the above is generic. Several factors must be considered. Engine condition and altitude are 2 of the primary ones.
The correct setting will allow the engine to idle well without loading up with fuel. The high speed not running too lean nor too rich.
The correct settings for your machine must also allow the engine to rev from idle speed to top speed without any hesitations, stumbling or dying.
The other resident small engine service and repair professionals may offer additional suggestions, advice & help.
Check back on your topic several times for additional replies.
Read the other postings and replies offered on this topic in the RECENT & ARCHIVES postings, within this forum, for additional help & information on this topic.
If you need further assistance, use the REPLY button to add any additional information or ask another question on this same topic, etc. Using the above method also moves the topic back up to the top of the list automatically.
Regards and Good Luck, Small Engine Forum Host & Moderator
Tom_Bart.....TCB4U2B2B.....Company Enterprises.
Fast...Fair...Friendly & Highly Efficient Services....
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
