Generator Engine Problem
Old 07-21-02, 09:12 PM
dougie
Honda generator
Hi I have a Honda generator 5500 watts 13hp motor water cooled motor. electric start
My problem is that when it runs it pump oil from the motor threw a hose that runs from the motor to the air filter houseing almost chokeing out the motor.
Any help would be appreciated
Old 07-22-02, 08:55 AM
telco tech
That hose is likely to be the crankcase ventilation hose. It allows combustion gases that get into the crankcase to be recirculated into the engine via the air cleaner. If the oil level is to high, oil can get sent back into the air cleaner along with the waste gases and flood the the cleaner element. Check the oil level, also make sure the unit is sitting on level ground, this can cause it to send oil back to the cleaner. Good luck.
Old 07-22-02, 03:25 PM
dougie
Thanks
Old 07-22-02, 09:25 PM
cheese's Avatar
Also make sure your air filter isn't clogged. This causes a lot of vacuum in the valve chamber and lets more oil accumulate in there than there should be.
Old 07-24-02, 04:36 AM
dougie
Thanks again
Trackbacks are On
Pingbacks are On
Refbacks are On
