Probably a high gloss oil based paint....I've also used something called an archetectural enamel. What are the cabinets made of? What are you painting over?
I'm getting ready to paint my living room.Where should I start? Do I cut in around the ceiling first and then paint the walls or do I paint my trim work first ,which includes a door? This is my first try at painting and I want to do it right.
My trim will be a different color from my walls.
Should my trim paint be oil based?
My walls are currently painted with a semi gloss latex. Would it be ok to paint over them with an eggshell or satin finish?
ThanksRead More
I have a concerte porch I want to paint but I don't know whether to use paint or a stain. The porch is covered so water settling on it would'nt be a problem. Also, later in the day the sun does shine on the porch area (did'nt know if that played a factor). I was planning on painting it a gloss tanstone color.
Also, would I need to apply a concerte etcher & rust remover? The area is virtually free of rust and heavy stains.
Thank you for your help!
Mike (Mesa, AZ)Read More
