painting over semi-gloss
Old 01-02-03, 05:53 PM
Carolden
I just finished painting my kitchen ceiling with a semi-gloss paint and I am not happy with the results. It shows every imperfection. Can I paint over it with a satin finish without priming again and will this help the problem?
Old 01-02-03, 06:03 PM
mikejmerritt
Hello Carolden, you can go right over the S/G with satin and it should help the problem a great deal. Eggshell would show imperfections even less.....Mike
Old 01-02-03, 06:11 PM
Carolden
I painted the walls with a semi-gloss, will the eggshell finish on ceiling look ok?
Old 01-03-03, 05:05 AM
mikejmerritt
I suppose that would be a matter of personal preference. I have learned here that in some areas the S/G ceilings are the thing to do. Around here there are few ceilings done in anything but flat finish so to me the S/G walls with eggshell ceilings would be a very nice look......Mike
Old 01-03-03, 03:13 PM
Carolden
Thanks Mike for all your help. Your opinions have been very helpful. I'm still deciding what to do. I will let you know how I make out.
Old 01-03-03, 07:38 PM
B
if I may ask....
What is the concern? Is it aesthetics or is there a problem you are trying to handle?
Mike is correct - most ceilings are done with a flat finish. Ceilings simply do not get dirty like walls and so don't need the extra protection/scrubability of a higher sheen.
Now a kitchen - depends on the foods you like to cook and how you cook them. If you cook a lot of high fat foods or use a deep fryer a lot, then you probably want at least eggshell or satin.
