"mdf" board used outside?
Old 01-12-03, 08:53 PM
jonandwendy
I need to replace furring strips around the trim on outside of house. Could I use the primered multi density fiber board outside it I painted it with trim paint? I live in a desert climate so moisture isnt an issue.
Thanks for any info
Old 01-13-03, 05:38 PM
mikejmerritt
Hello jonandwendy, I wouldn't put my time into the project unless the MDF was rated for exterior use. If you had to use the MDF without knowing what grade it is prime all four sides and both ends of every piece with an oil based exterior primer...Mike
