Painting Over Wallpaper ?
Old 05-23-03, 01:49 PM
roger knott
Do you have to use some kind of primer when painting with latex semi-gloss over existing wallpaper ?
Old 05-23-03, 03:12 PM
C
It is best to remove the wallpaper.
A blocking primer such as Zinsser 123 will help hide any colors in the wallpaper and provide a good bonding surface for the paint on top of the cleaned wallpaper.
Hope this helps.
Old 05-23-03, 04:36 PM
roger knott
Thank you Chris
Old 05-28-03, 02:21 PM
MsAnnie
Don't!!
My recommendation is don't paint over the wallpaper if you think you may ever want to remove the paper! I have two rooms that were done this way by prior owner - removing the paper takes days, yes days. I have to score it so that no more than one square inch remains unscored - then the steam will work slowly with lots of scraping. Wallpaper remover goop has no effect on it at all.
Old 05-28-03, 04:07 PM
roger knott
O.K. Annie ,thanks for the good advice!!! Roger
