peeling paint
Old 06-25-03, 10:05 PM
Blondielan
peeling paint
I have come across an interior wall that was previously painted with oil based paint & then with latex. The oil paint is now peeling under the latex. What is the quickest & cheapest way to fix this?
Old 06-26-03, 07:02 AM
Failure of the paint to bond to the substrate is a fatal problem. If it is peeling off of the wall, there is little you can do other than scrape the failing paint from the wall, clean the wall with TSP or spic and span or its equivalent, prime with a good primer sealer such as Zinsser 123, and paint.
Hope this helps.
