bleed thru!!!
Old 07-12-03, 05:37 PM
fatkid66's Avatar
Unhappy bleed thru!!!
spraypainted moldings w/ gold metallic paint a couple of years ago cause it looked cool. painted killz primer over it to change the look, and now as it drys im getting bluish bleed thru the white primer. its the pigment in the spray right? how can i fix this??? can i fix this??
Old 07-12-03, 06:07 PM
C
Sometimes it takes two coats of kilz or zinsser to cover certain products. The sign of this need is the bleeding through the first coat of primer.
Old 07-13-03, 05:02 PM
mikejmerritt
Question?.......Are you using KILZ Original? The latex primers are pretty weak in the stain killing dept.......Mike
