Covering dark paint
Old 08-29-03, 05:20 PM
Ljohnson004
Question Covering dark paint
HELP, please!! We are moving out of a rental and have a small bathroom that we painted with Interrior Latex Semigloss Enamel - bright blue - and need to paint it restoring it to Swiss Coffee Acrylic Vinyl. Any suggestions???
Old 08-29-03, 06:17 PM
prowallguy's Avatar
Pick a color, 2-3 coats should cover anything.
Old 08-29-03, 06:39 PM
Ljohnson004
Talking Thanks ProWallGuy
Really, great, should it be acrylic or enamel? Should I use a primer as the first of the three coats?
Old 08-29-03, 06:59 PM
C
The primer will help cover the old color. After a good primer, one coat may well do it.
Acrylic, latex semi-gloss paint is a good choice. The term enamel is a throwaway term that sometimes appears in paint names. It means glossy finish or one like it. I have seen paints called latex enamel semi-gloss....go figure.
Hope this helps.
Old 08-29-03, 08:57 PM
R
just a tidbit.you can have primer tinted to match the finish paint color at the paint store.and yes to make drastic color changes require more than 2 coats of paint .prime it with one coat and maybe even 2 coats first.primer covers and hides better than paint.
