painting a shower/tub enclosure
just curiuos if anyone has used any of the doit-yourself kits to change the color of their tubs? our tub enclosure is golden harvest and we want white. is it possible to do it myself without having to replace the assembly? just how long will it last if it's repainted?
I have a friend who used this service and was quite satisfied.
http://www.miraclemethod.com/
Hope this helps.
Hope this helps.
Painting a shower/tub enclosure
I have used a do-it-yourself kit for doing what you have described. I have used a specialty product made by Rustoleum called the "Tub and Tile Refinishing Kit". It can be used on fiberglass. porcelain, acrylic, cast iron, steel and ceramic tile. I buy this product at Menard's. I used it on my ceramic tile kitchen backsplash.
I am not sure how long the finish lasts, but my tile has held up quite well! The prep is the hardest part, but is well worth it for the results. The product does come in white. The only thing about using it in the shower is that you cannot use the spray-on shower products like "Clean Shower" on the finish.
I was pleased with the product and would not hesitate to use it again.
Good luck with your project!
