Two coats with semi-gloss
Received 0 Votes
Something I've always wondered about: When painting, say a bathroom, in a latex semi-gloss and you discover that you need more than one coat, do you pros just apply another coat directly to the first coat without any surface prep, or do you go through the trouble of deglossing (via sanding or TSP) the first coat, so that the second coat will stick to the first? If not, why not? How about an alkyd base semi-gloss?
Received 0 Votes
Just do a second coat
I've never had a problem just doing a second coat. The second coat will bond to the first coat. I always use a quality latex. Don't know what would happen with paint from a big box or discount house.
Received 0 Votes
Yeah,that's what I've always done too. But why then, do "they" always want you to degloss paint with TSP or sanding? Does it have something to do with the fact that the paint coat is still fresh, and it makes it stick better for some reason? Why bother ever deglossing semi-gloss paint?
Received 0 Votes
Old finishes are considered to be dirty. TSP is a degreaser - cleaner. You cannot paint over dirt. Any surface must be mechanically sound and clean for successful painting.
Deglossing is a preference generally reserved for gloss finishes, although some do it for semi-gloss.
Hope this helps.
Hope this helps.
