textured ceiling patch up
Old 12-07-03, 12:17 PM
fbdrew108
I painted my kitchen and accidently got some paint on the ceiling. I used a wet rag and wiped off the paint and slightly smeared the textured drywall. Is there anything I can do or use to patch this up?
Old 12-07-03, 04:07 PM
prowallguy's Avatar
Received 1 Upvote on 1 Post
You can use whatever the texture was made of, probably some sort of joint compound, or acoustical(?) material. Either way, repairing/matching texture is pretty darn hard to do.
Old 12-08-03, 05:53 AM
fbdrew108
I thought it may be difficult to do. Thanks for the advise.
Old 12-08-03, 06:50 AM
coops28's Avatar
What kind of texture do you have?
Old 12-08-03, 08:16 AM
B
sounds like a "popcorn" texture
That kind of texture is easily smeared by a wet rag. If so, its weasy to fix. Hardware stores even carry spray cans of the stuff. Just follow directions on the can.
Other textures I'm familiar with wouldn't be affected by wiping with a wet rag, especially if it was painted.
Old 12-08-03, 10:46 AM
coops28's Avatar
Good point Bobf. Just trying to make sure. The spray stuff should work in this case.
Old 12-08-03, 12:56 PM
fbdrew108
Thanks guys for your help, I'll try the spray can try it out.
