removing adhesive?
removing adhesive?
I recently moved into a new home. The downstairs bathroom had plastic tiles covering half the wall all the way around (they were painted). A couple had come loose and I decided to "pry" the rest off.
I am now left with a lot of remaining glue/adhesive. Outside of using any harsh chemicals, any tips on how to remove this stuff?
I'm currently using a putty knife and scraping/chipping away, but it's taking forever...
Thanks in advance for your help!
Is it old, dry, liquid nails?
No chemicals I know of will work on drywall without ruining it anyways.
Scraping is one way, using a belt sander or palm sander is another.
There is no easy way.
P.S. If its not too bad, you could resurface the wall with joint compound.
It appears to be rather old. I'm about 3/4's of the way done scraping (chipping) away at the glue. It's taking forever and unfortunately, I'm causing a fair amount of minor damage to the plaster walls.
The damage I'm doing is a lot of very shallow small "dings" in the wall. Am I better off using spackle or joint compound in repairing the "dings"? Is there much of a difference between the 2?
For small dings, I use spackle. If there are alot of dings, I use joint compound solely for the fact that I can float several at once.
Chemically and physically, there is a difference in spackle and j.c.
But both go for the same end result.
I use spackle for small dings, divots, nail holes etc., and use j.c. for larger problems. If I want to acheive a smooth, glass-like surface, I use j.c.
