Pitch
Pitch
I installed a lam-beam that I want to leave with a natural. clear finish using water base varathane. However, there are a couple spots that are bleeding pitch that have discolored the wood. I know shellac is best to seal these spots, but what can I do to remove the pitch and decolorize the spot?
I would try to clean off the pitch with laquer thinner. Try on a real small spot to see if it work before applying it heavily. You might need to use some wood bleach on the spots to lighten them up.
And if you have oozing pitch, I wouldn't consider water base anything an option. I would use varnish or shellac.
