how smooth to power sand before painting
Old 02-15-04, 12:31 AM
gregs
Hi folks,
I've been heat stripping and power sanding (both a random orbit sander and a 3D sander) my wood stair railings. My question is...
What should my final grit be on the sandpaper for the power sanders before I prime? I was about to go very fine (400 grit), but then I was wondering if you can actually make it TOO smooth for the primer and paint to stick.
Forgive me if this is a stupid question; I'm new at this.
I'd like the railings to be as smooth as possible after primering and painting, but I don't want to have to re-do it in a couple years.
Thanks!
Old 02-15-04, 06:20 AM
prowallguy's Avatar
No, you can't make it too smooth for the paint to stick. I've painted glass, metal, and finished plaster is very smooth.
Make sure to use a tack cloth on it after sanding to pick up the dust and crumbs before painting.
And also lightly sand and tack cloth between each coat applied.
Old 02-15-04, 09:50 AM
gregs
That's exactly the answer I was looking for. Thanks!
