Plastic enamel?
Old 03-07-04, 08:49 AM
T
Plastic enamel?
I will be painting some kitchen cabinets with Varathane Colors in Plastic, Plastic Enamel. I've used this on steel doors in the past with great results.
My question is- my cabinets are solid wood (pine) with a lacquer or poly finish. What is necessary to prepare for the new finish, if anything? I will wash them down with TSP, of course, but do I need to give them a once-over with steel wool, before applying the plastic enamel? There is no info. on the can or the pamphlet covering this.
Thanks for any help.
Old 03-07-04, 02:08 PM
prowallguy's Avatar
Received 1 Vote on 1 Post
I would. Sure can't hurt.
Old 03-07-04, 04:14 PM
Dave_D1945's Avatar
I would skip the steel wool and use 150 grit sandpaper and/or a "Fine" grade sanding sponge. You don't need to remove a lot of paint, just scuff it up a little so the paint adheres.
Old 03-09-04, 03:46 PM
T
Thanks
Thanks for the advice.
Tom
