painting textured ceiling
Old 03-28-04, 10:42 AM
bub3683
i made some necessary repairs to my textured ceilings, and now i want to paint them. they were made with thinned joint compound and some sort of patterned sponge or brush. i plan to use a flat, off-white paint. do i need to prime the ceilings first?
Old 03-28-04, 07:25 PM
prowallguy's Avatar
Received 1 Upvote on 1 Post
I would at least prime the repaired areas, if not the whole thing.
Old 03-28-04, 07:26 PM
awesomedell's Avatar
prowall,
pop over to framing & subflrs & see if that photo test link works for you pls
Sorry for the off post, do prime the whole ceiling & then paint, might even double prime the repaired area for best results.
Old 03-28-04, 07:29 PM
prowallguy's Avatar
I see the announcement, not sure what you want me to do after that.
Never mind, I figured it out.
Old 03-28-04, 08:38 PM
The announcement thing is at the top of my forums I mod on, anyway you found the photo test, do you ck your PMs?
Sent one just now about the photo thing again & also had one about the true-tex I think it was called, mesh run between two layers of poly resin or something for repairing damaged walls.
