bathroom painting ?s
I am remodelling a bathroom and had 5 questions. I hope this is the right forum, it may overlap a bit with the wall and cieling folks.
Skylight over tub: I have "boxed" it in with green drywall
Cieling: nasty mildewed glossy paint, with bad patch jobs which I will repair with mud and sanding
Walls: stripped wall paper down to light blue flat paint
I want to texture EVERYTHING before painting.
1. Should I primer before and after texturing?
2. Is there any other prep recommended, like using TSP or TSP substitute?
3. Is there a single primer I can use for everything i.e. over new drywall, old paint, and new texturing?
4. The bathroom will be light pink semi-gloss...should I tint the primer?
5. Can you recommend paint brand that will work well in a bathroom..mildew resistant?
Thanks for any help!
Chris
Chris
I'm just going to 2nd everything prowallguy said..... perfect advice. the kitchen and bath paint he recommended is more of a satin finish opposed to a semi-gloss. Zinsser makes a similar product that is a true semi-gloss and has a stated 5 year warranty on mildew. personally, the semi-gloss is a bit to high of a sheen for me, so I would stick with the benajamin moore product. and one other thing for emphasis, you must kill the mold before painting. some people seem to think that a mildew resistant paint can go right over mildew... and low and behold, 6 months later, the mildew is coming through the paint and there isn't anything you can do about it. I've found a 4-1 water to bleach ratio is best.
