pva instead of primer?
Old 06-20-04, 05:27 AM
arlen nimchuk
I'm trying to finish my stair case that was built with 2x4 framing, with some drywall along the bottom corner. I've used pva on the drywall. Can I also use it on the wood, instead of primer? I live in Japan, and have checked into buying primer paint. Options are: spray can (would take quite a few) or buying a huge drum of paint from a store that usually deals with professionals. The 2x4's have a lot of knots, so I'd like to come up with as smooth of a finish as possible. Will appreciate any advice/thoughts.
Old 06-20-04, 08:59 AM
prowallguy's Avatar
PVA is good for bare drywall, but I wouldn't recommend it on wood. Try to find some BIN shellac-basec primer for the knotty wood. If not, then any alkyd or oil penetrating primer will work.
Old 06-21-04, 06:40 AM
arlen nimchuk
Bin?
Sorry, what's BIN shellac? I've heard of shellac before but never BIN.
Again today I did some shopping, and stores do not seem to stock ANY wood primer other than in small spray cans. I will look for shellac, or alkyd or oil penetrating paint.
Also, will the 2x4 frame ever look smooth and nice (granted, nice is a relative term). I imagine there is a limit as to how beautiful it will ever look. We went with the 2x4 staircase railing because the housing company considered the railing as an afterthought, and we only had a limited budget by the time it was being built. It's strong enough, but scores low marks on beauty right now.
Old 06-21-04, 09:31 PM
arlen nimchuk
Another possibility?
I noticed that I still have a can of Varathane that was bought when our other paints were bought from Canada. Is is possible to use Varathane as a primer, before painting the wooden staircase railing?
