Slightly DUll Gloss Polyurethane
Hello,
I am refinishing my kitchen cabinets. I first tried a spot w/ matte finish polyurethane (oil) but wanted more gloss. SO, I coated all w/ a high gloss poly (oil). But, ideally, I'd like a slightly duller finish. I thought I have seen how to gently dull a gloss poly finish. Any suggestions?
Also, I got alittle sagging in the existing finish cause I rushed the prep. sanding some. I can live w/ it if I can't easily remove it.
Thanks for any assistance!
Sparkie
Sparkie
Hi Sparkie,
If your matte and gloss are both oil base and the same mfg., simply mix them until you get the desired finish.
Best to remove the doors and lay them flat for a more even finish, as most polys are self leveling.
Also, I usually thin with mineral spirits - then any sagging is more easily brushed out if done quick enough.
Poly is not easily buffed/rubbed to dull the finish. Ground silica is used in the matte to dull the reflective properties.
good luck,
fred
good luck,
fred
