Painting Circles
Old 08-29-04, 07:32 PM
Lightman
Smile Painting Circles
What is a good tape to use to tape off a circle I am painting on a ceiling
Old 08-29-04, 07:34 PM
Lightman
Also if anyone has any tips on painting circles please share.
Old 08-30-04, 04:44 AM
B
tape would be hard to use
Tape is going to be hard to make look right.
How big of a circle? I suggest something thin as a template. You can use double-sided tape to hold in place. Or, if its feasable, use a string, pencil, and brad (nail) to draw the circle. Use a VERY light stroke. Then carefully hand paint on the outline. The tiny hole from the nail can be easily patched.
Old 08-30-04, 05:10 AM
Lightman
4 feet
The circle is 4 feet, I was planning on sketching it out with the pencil and string method and then taping it off
Old 08-30-04, 12:48 PM
doing it with a pencil and string is one way.Keep the pencil perpendicular to the ceiling. After you do it go around the line with the corner of a small spackle knife to create an unnoticible groove. When you paint go up to it and let the paint flow into it.
Old 08-30-04, 06:34 PM
Lightman
I had a similar idea...I was going to go over the lines with a razor blade but I didn't want to cut into the paint I think I'll use your method
Thanks
Old 08-30-04, 07:14 PM
another way would be to make the circle with the string and then cover the line with blue tape or safe release tape leaving plenty of room on each side . then make the line again and cut off the line with a razor or a . sort of burnish the edges to keep the paint from getting under it. Make sure you don't have any creases in the tape and use a sharp blade. Remove the tape immediately after painting.
You could also use a piece of 1 by 2 about 5 feet long and drill a hole about 3 inches from 1 end and insert a drywall screw as the pivot point. Then drill a small hole for, like a finish nail or a pencil, exactly 48 inches away and make your circle. patch the small hole the drywall screw made. This may produce the roundest circle
Just a thought about using the spackle knife edge to make the groove If you choose that method. Try a butter knife first to see if it works. Might be easier and less chance of chipping I would think,and it might make more of a groove than a cut,because it's rounded.
Old 08-30-04, 10:46 PM
Lightman
won't it be hard to tape with the blue tape because it's round lines?
Old 08-31-04, 04:48 AM
B
make a template using the tape
I think what joneq means is make the first circle so you know where to put the tape. Now trace the the circle on top of the tape and cut away the tape inside the circle. The tape is now your template.
Old 08-31-04, 08:37 AM
prowallguy's Avatar
Received 1 Upvote on 1 Post
That was a good idea. I like the style with taping over the line, retracing it, and cutting the excess out. That would work pretty good.
Old 08-31-04, 08:35 PM
Lightman
it's time
well here goes nothing I'll try and get some pics up on the web when I'm done
Old 08-31-04, 11:35 PM
I would tape the circle after using the screw, string, and pencil drawing. If you use a narrow tape it will easily bend to a circle. 1" tape wont cut as small a circle as 3/4", so I would try to find some 1/2" and try it. Cutting with a razor will be time consuming and if the pencil line is accurate it will be hard to notice minor irregularities. Very narrow tapes ( 1/8" fineline ) can be had at autobody supply places but if you are going over texture or rough surface getting it to stick will be a problem. After taping you can paint clear faux finish over the tape edge to seal it from bleeding under, then razor cut the tape edge to pull off the tape. I would just brush (cut in) the flaws out as this would be quicker.
Old 09-08-04, 11:58 PM
Lightman
Success!
Job done! Thanks for all the tips, in the end I used the nail and string method and then taped it off with easy mask strechy tape or something like that.
Check it out
Click here
Any feedback is welcome
Sorry no fancy website but I wanted to share
Old 09-09-04, 04:57 AM
B
Great job!
Thanks for sharing the end product with us.
Old 09-09-04, 09:28 AM
prowallguy's Avatar
Very nice. I'm a Cub's fan from way back.
