how to pain between the wall & ceiing
Old 10-08-04, 07:44 AM
trusert
How do you get paint between the wall & ceiling so theres no white left or the old paint showing. I used a border paint brush but the old paint is still showing & i cant get close enough between the tight space. Also when taping should you use the double wide scotch tape..
help i have a big sripe of the old paint still showing.
Old 10-08-04, 09:00 AM
prowallguy's Avatar
The best way to fix that is to paint your ceiling, and wrap the ceiling white down onto the wall about an inch. Then when you paint the walls, you cut in the wall paint upto the ceiling line.
Old 10-08-04, 12:55 PM
I got the feeling you are using a crappy brush or cheap paint. Probably the former. Use a good brush. Purdy is a good one to look for
