Silicone caulk mistake
Old 10-08-04, 08:43 AM
I accidentally caulked with silcone caulk in some areas that need to be painted on the exterior of my house - specifically all around some new brickmold I installed. Do I need to remove this, or is there some way that it can be painted over??? I'm such an idiot!
Old 10-08-04, 08:53 AM
jatco's Avatar
Received 1 Vote on 1 Post
I dont think I would bother trying to paint it. You could try a good primer to see if it takes, but I would probably just caulk over that silicone with painters caulking..and save yourself some time.
That will stick to the silicone caulking
Old 10-08-04, 09:04 AM
prowallguy's Avatar
I would prime the silicone with an exterior alkyd primer, then hit it with the latex finish paint.
Old 10-09-04, 09:46 AM
jatco's Avatar
Will the primer stick to the silicone???
Old 10-09-04, 05:20 PM
prowallguy's Avatar
Yep, but it can't hurt to wipe the silicone down with thinner first to remove some of the oils. Is it a permanent fix, no. But it will adhere stronger than latex paint or caulk.
Old 10-10-04, 07:52 AM
jatco's Avatar
Kewl. Thanks for that. I'll keep that in mind!
