cherrywood paneling
Old 10-22-04, 09:45 PM
x2exercise
Smile cherrywood paneling
Hi, I have cherrywood paneling in my livingroom, its a smooth paneling, can anyone tell me what i need to do to paint it.
Also I have a black trim on the top near the ceiling which is plastic, "suppose to look like wood" I don't want to remove it because I have a popcorn ceiling and afraid I will have a space, so could you tell me how i should paint that also.
Old 10-23-04, 08:36 AM
prowallguy's Avatar
Wash it down thoroughly with TSP to remove all the oils, waxes, cleaning products, etc. Sand it with 120 grit sandpaper for adhesion. Remove all the dust (vac, tack cloth, swiffter, etc.). Prime it with a penetrating alkyd/oil primer. Some would suggest a latex primer, which very well might work. But I'm from the old school, and prefer to use something that will penetrate and dry fairly hard. After its primed, caulk all the joints of the paneling, and up at the top where the trim meets it. Or any other spot that will provide a seamless surface. Then top coat it with ant latex product you desire, 2 coats for durability and even sheen level.
