wallpapered corner cracks
Old 03-12-00, 07:27 AM
Guest
Question
how can i fix a wallpapered corner crack prior to painting to insure a good looking result? Wallpaper to remain on wall.
Old 03-14-00, 04:26 AM
Guest
Post
I'm a bit confused. Wallpaper doesn't crack. There's not much you can do. A crack is normally fixed with either spackle of joint compound. Both these products contain water and the water will soften/loosen the wallpaper paste. Then the paper will be loose in spots - worse than it is now.
To get the best result, remove the wallpaper.
[This message has been edited by BobF (edited March 14, 2000).]
