Paint that bubbles
Old 04-09-00, 07:59 AM
Guest
Post
I am repainting wall and have a problem with the paint underneath bubbling. I am using a latex paint but have no clue the type of paint I am going over.
Old 04-09-00, 08:55 AM
Guest
Post
Its hard to advise without seeing but a couple of thoughts.The moisture in the new paint is lifting the old paint.If after a day these bubbles are still there it is safe to assume they will not dry out.In that case you will have to seal the wall with KILZ or some oil based primer to block the water in the new paint.
Old 04-16-00, 10:42 AM
Guest
Post
[QUOTE]Originally posted by Humidity in the air is very important when paintin regardless of the kind of paint you are using . I think is not the old paint that is bubbling but the new one. Paint solvents try to escape during the process but get trapped with cold air around . Watch the sun when painting.
