old paint removal
Old 07-11-00, 08:26 PM
Guest
Post
paint is peeling off my garage. i think it is just wood shingles. i have all kinds of low spots and it looks like crap. i do have 1 coat of oil based primer on now. thought that might help. i also tried 60 grit sand paper. that did no good. what do i have to do to get the wood all smooth. replace it. or use a heat gun. is there some kind of filler. thanks
Old 07-23-00, 02:17 PM
Guest
Post
Try using PEEL AWAY 7 and it will remove the paint easily and give you a clean surface so you can make your own choice in re finishing
