water damaged sheetrock ceiling
Old 06-30-00, 04:55 AM
Guest
Post
what is the best way to repair minor water damage to a sheetrock ceiling before painting
Old 06-30-00, 09:01 PM
Guest
Post
What is your definition of minor. Describe the damage and I'll give you a definitive answer.
More than a Carpenter
http://www.carpenter.cjb.net
Old 07-01-00, 05:09 AM
Guest
Post
Joet:
If you are referring to water spots that will bleed through when you paint it, first paint it with a stain blocker. All home improvement centers have it. You only need to paint the stain. It will be about $15.00
for a quart. Works like a charm. Make sure the water spots are dry. If the sheetrock is soft, you will need to replace that section. Good Luck
Old 07-25-00, 08:34 AM
Guest
Thumbs up
Kilz has a product called UPSHOT - which will cover the discolored surface and prevent it from bleeding back through new paint. It's available at Home Depot and is not expensive.
