colorwashing
hi im trying to see if anyone can tell me exactly how to colorwash my walls? please help me ! i have a flat base coat down on hte wall allready and i have a some semi gloss of the same color but im not sure how to apply the overwash or to mix it please hepl me thank u
quote:<HR>Originally posted by latonya:
hi im trying to see if anyone can tell me exactly how to colorwash my walls? please help me ! i have a flat base coat down on hte wall allready and i have a some semi gloss of the same color but im not sure how to apply the overwash or to mix it please hepl me thank u <HR>
I am looking for the same info. I have seen different ways to do this technique and am not sure which to use. The easiest that I have read about is to mix the top coat color up to half water, half paint in a spray bottle. Spray a small area of wall at a time and then with a dry rag, rub in circular motion on wall. This is the technique that I plan to try in a few weeks. I am stumped on how to choose which color for base and top coat though. Hope this gives you an idea!
<HR>
Forgot to mention that you should use a water based latex paint since you will be mixing it with water. Good Luck!
my husband had bought me a painting book from home depot it has everything you need to know aboout painting wall,molding,faux finishing the name of the book is step-by-step DECORATIVE PAINTING ITS GREAT IT WAS ABOUT 12.95 WELL WORHT THE MONEY. GOOD LUCK
Color washing as described in Recipes For Surfaces......Techniques in which thin layers of very transparent glazes are applied with a roller or brush,then worked over with a sponge,cloth or brush and finally smoothed and blended to varying degrees with a soft haired brush......This book was bought at Lowes and now has a 2nd edition out...Mike
