painting tiles
I spray painted my tiles but now they are all uneven,and ugly!!!!!!!!!(in the bathroom) What kind of paint do I buy to cover it up? I want a little sheen to them..can I use a regular paint brush?
If you are looking for a one step process for repainting you will have to go with an oil paint.Dull the gloss by sanding first.This could be applied any way you choose.If you would like to avoid brush and roller marks and since you have spray now try a spray from Sherwin-Willaims by the name of SuperAcrylic.This is some of the best paint I have ever used and has a fan pattern much like a real gun.Very easy to get smooth and uniform.Try a sample spot of this paint and let it dry because as with all acrylics it tends to wrinkle some paints.All coats of this paint must be apllied within 2 hours of each other because it will even wrinkle itself... Mike
