Textured Batroom ceiling
Old 01-24-05, 02:45 PM
weewillie
Planning to use W/R sheetrock on a batroom remodel,(2nd floor) then have it taped and sprayed with a textured finish. Will also be installing a combination heat lamp/ exhaust fan.(venting thru attic to roof vent) Will there be any problems down the road with peeling,or mold on this type of ceiling? Thanks.
Old 01-24-05, 05:30 PM
prowallguy's Avatar
Received 1 Upvote on 1 Post
Do you plan on painting the ceiling after the texture is applied? If so, use a kitchen & bath paint, which is formulated with mildewcides and mold inhibitors.
Old 01-24-05, 06:21 PM
weewillie
I wasn't planning to paint it after it's textured. If i do, what is the preferred technique?
Old 01-24-05, 08:31 PM
prowallguy's Avatar
If the texture is made with a joint compound-like substance, then it will be susceptible to mold if the ventilation isn't excellent. I would apply a coat of Zinsser's GARDZ as a primer, and 2 coats of k & b paint for finish.
Old 01-25-05, 07:00 AM
B
Holy paintbrush, Batman!! Sounds like weewillie is going to spray a popcorn finish since it wasn't going to be painted.
Old 02-08-05, 03:53 PM
weewillie
Hey Bob. Can you explain what you mean by a "popcorn finish"
I wasn't aware that you could paint over a sprayed textured finish, do you use a high nap roller, or what works best?
Old 02-09-05, 08:43 AM
B
Popcorn is the accoustic material the is used in many, many homes now because its cheap. You don't need to finish the ceiling as you would for painting and the stuff is sprayed on and not painted. Saves the builder $$ in labor.
Yes it can be painted with a thick nap.
