crayon wallss
i am having trouble removing crayon from walls painted with semi-gloss white.all colors of the box were used.also has border on wall how to remove without damaging wall.........thanks......................................thanks for the advice its appreciated..i enjoy this site.
[This message has been edited by mstrug (edited September 04, 2000).]
Seal the walls with the color crayons on it with a primer sealer such as Ben Moore Fresh Start. Then you may paint.
As for the border, is it vinyl or what. If it is vinyl, uou may be able to strip it off. You can also get a paper tiger which when rolled over the border will put thousands of small holes in the border. Then spray wallpaper remover over the border, allow it to work the recommended time and then scrape it off with a putty knife.
