Exterior preping
Old 09-05-00, 04:55 PM
Guest
Post
What is the best way to prep exterior siding (T-111)? The existing paint is peeling in some places but not to an extreme. If I pressure wash it, how long should I wait before putting an oil based primer?
Thanks
Old 09-05-00, 08:20 PM
Guest
Post
If you live here in TX you can prime it in about 10 minutes (just kidding, it's been up to 108 degrees)
After you presure wash it, I would go around with a scraper and make sure all the lose or peeling paint was removed. Depending on your weather as to when you can prime, I would at least wait a day.
Remember the primer and paint needs to be exterior and I would suggest from a pro paint store for best results.
