Painting over dark wood paneling
Old 03-09-05, 06:35 PM
lj8576
Hello
I was wondering what the best way would be to paint over dark wood paneling. I have a room thats too dark and I want to lighten it up a little bit by painting it white or a brighter color. ANy help would be appreciated. Thanks
Larry
Old 03-09-05, 07:38 PM
I would prime it white first with Zinnzer's 123 to seal it, get better adhesion and (in case it needs it) block any stains from bleeding through.
Old 03-09-05, 07:54 PM
lj8576
OK Great thanks. I assume I can get this at home depot or lowes right?
Old 03-09-05, 08:34 PM
lj8576
Would I have to rough it with sandpaper, or just paint over the primer?
Old 03-09-05, 08:38 PM
Any paint store or H.D. or lowes. You don't have to prep the primed surface just paint.
Old 03-10-05, 06:47 AM
K
What type of finish is on the paneling now? Even with Zinser you will need to rough up any gloss finishes to insure adhesion.
Old 03-11-05, 09:22 PM
Nanledaroe
Painting over wood paneling
My husband is a professional painter and right now he's in the process of painting our 1960s dark wood panelling in our den. For years, we've refered to our den as "The Cave". First thing he did was to sand the panelling a bit to give it a little "tooth". Then he cleaned the walls off very well. He used Kilz oil based primer and then, later went over that with 2 coats of Porter latex semi-gloss in "Newport Beige" (of course you can use whatever kind of paint you want to). Our old dark den now looks light, bright and much bigger. Good luck with your project......I know you'll love it when you're done.
Old 03-11-05, 09:29 PM
lj8576
Thats what this room looks like a dark cave. Thanks for the advice I am sure it will look much better when it is done
