Chipping paint - another questions
Old 03-23-05, 07:54 PM
I am having a similar problem as another recent post. I am having small bubbling on a more recent paint job that was done before I moved in. It is happening on molding. If I read correctly, the recommendation is ;
-Chip away loose paint
-Sand down the old surface, smooth out the crack areas with a hand sander
-prep and paint.
Home Depot recommended "gripper" as a primer then paint as normal. Does it matter if I use latex or Oil?
All sound about right?
Old 03-24-05, 05:22 AM
prowallguy's Avatar
Received 2 Upvotes on 2 Posts
If there is an existing adhesion problem, I would prep as you said, and use an oil or alkyd primer to aid adhesion. Then top coat with a latex trim paint.
Old 03-24-05, 05:25 AM
Received 862 Upvotes on 754 Posts
Smile
Sounds like the woodwork was repainted with latex over oil base or at least an oily or greasy surface. Since it has already been coated with latex I would continue to use latex but your prep work is very important. Try to remove all loose paint then sand good.
