Painting doorway .. and door
Old 03-31-05, 08:56 AM
G
I would like to paint my doorway and the door over the weekend. Both of them are in blue color and I would like to paint a beige semi gloss color. I have a few questions:
a. Should I use a primer? If so what type?
b. Do I need to remove paint from the door?
c. What sequence do I use? Paint door first and then the walls or vice-versa?
Thanks!
Old 03-31-05, 09:30 AM
erkinator
prep
Painting over alike paints is no problem..Oil/Latex. If the paint is sound, just sand and clean with good prep cleaner from the paint store.Then paint away.I paint trim first except baseboards.Then I do the walls.It easier to get a strait line down the walls to meet the trim paint than vice versa.Its usually personal preference.I used to be a contractor so have fun and open some windows if possible.
Old 03-31-05, 11:37 AM
G
Heat gun?
Do I need to use a heat gun to remove paint off the door first?
ALso, do I need to go for different kinds of paint for door and walls?
