Painting Procedure
Old 04-08-05, 01:43 PM
bwlpf
Painting Procedure
A very basic (spelled "dumb"?) question, but what are the recommended steps in re-painting a room. Everything now has fresh primer on it. We assume the ceiling is to be painted first. Then, is it Walls before Woodwork? Or vice versa?
Thanks!
BW
Old 04-08-05, 03:35 PM
prowallguy's Avatar
We do ceilings first, then woodwork (minus the baseboard), then walls, then last of all the baseboard.
Old 05-01-05, 02:37 PM
kdnovak
We painted the ceiling, then walls, then trim...it worked, but it probably doesn't matter....
Old 05-01-05, 02:43 PM
Received 300 Votes on 266 Posts
Painting the trim [except base] is usually the easiest way to go especially if the trim is a different color than the walls.
Old 05-02-05, 05:27 AM
H
Ceiling, walls, then trim. You won't have to tape the walls when you paint the trim. Typically trim has a glossy surface so when you remove any painting tape it won't peel up any paint, especially a problem if the surface has been freshly painted.
