Painting over Laminate
Old 05-24-05, 06:40 AM
clovesl1219
We just bought a new house and are in the process of painting the walls. Although, in the kitchen the previous owners painted the sides of the kitchen counters a bright yellow. What would be the best way to remove the paint from the cabinets?
Thanks
Old 05-24-05, 06:43 AM
Received 330 Votes on 293 Posts
First I would try something like oops or goof off, if that doesn't work laquer thinner should remove it.
Old 05-26-05, 07:30 PM
D
Question
Is it the cabinets or the sides of the counter painted yellow? Counters, I'm not that familiar with- cabinets - I may be able to help. If it's cabinets, are you planning on painting them, or stripping down to the original finish?
Old 05-27-05, 09:38 AM
N
are you wanting to get it back to the original laminate?? or just change the color of the paint. because stripping that paint would be a pain. M1 remover/goofoff would work fine, but lacquer thinner could be a bit dangerous. if there is any crack in that laminate and that lacquer thinner gets behind it, that glue is toast. i would HIGHLY suggest priming it and then repainting. good luck
