Orange peel effect on painted kitchen cupboards
I have just started painting my kitchen cupboards. It was recommended by the paint store that I use a 'sponge' roller for a smooth finish, but it has produced an orange peel effect. I am using latex paint. Is there a way to remove the orange peel effect? What should I be using to get a smooth finish? I was originally going to spray them, would that have been a better choice?
Received 0 Votes
All is not lost, but you may have to do more sanding than usual. The secret is tipping off the paint. Use a brush to pull the orange peel speckles out. I've used both a regular dry brush and a foam brush, and have mastered the art. Do a search of the site for "tipping off" for the pros tips.
Good luck
Good luck
Never cared for the foam rollers but it is hard not to get orange peel with a roller unless you 'tip' the paint off with a brush. Adding a little floetrol to the paint will also help.
Thanks for the replies. I have searched the entire site and cannot find anything on 'tipping off'. If I use a brush to to knock down the orange peel effect, won't I be leaving brush strokes?
The idea is to lightly use the tip of the brush to go over the wet paint. A light touch coupled with a good brush will barely leave brush marks which often can't be seen unless studied.
