Removing Oil-Based Paint From Door Knobs
Old 09-20-05, 03:54 PM
R
I somehow ended up w/ oil-based paint on my oil-rubbed bronze door knobs.
I called the mfr, Kwik-Set & they don't recommend anything stronger than vinegar/water 50:50. Any other suggestions?
Old 09-20-05, 06:55 PM
Received 264 Votes on 234 Posts
One of the advantages of using oil enamel is how hard and durable it is, which also makes it harder to remove. Lacquer thinner or deglosser [with plenty of elbow grease] should remove the dried paint. There are times that it also removes the brass plating which is why the manufacture doesn't recomend anything strong. You may need to decide which is worse - paint on the hardware or clean hardware with missing or discolored finish. Wish you luck
Old 09-20-05, 07:13 PM
I'm afraid it may come down to this
Old 09-20-05, 07:44 PM
R
I guess I can hope by constant handling of the door knobs, over time the paint will wear off.
