To Keep Paint Spray Nozzzles From Clogging
Old 09-26-05, 09:25 AM
R
After I finish spray painting, I invert the can & spray till it appears only air is being emitted, but when I go to use the can weeks later, the nozzle is clogged. Is there a chemical I can use to to unclog the nozzle & how do I apply it?
Old 09-26-05, 10:48 AM
Received 330 Votes on 293 Posts
Sometimes you can take a needle and unclog the tip. I assume any solvent that would disolve the dried paint would also melt the tip.
Old 09-26-05, 03:52 PM
Not really
The way you describe should work
I use it with success
Perhaps you should let it spray "clear" a bit longer
Also you may want to have a few extra "known clean" nozzles and switch them when they clog
Most are replaceable with only a small ammount of mess
