How many coats of primer?
Old 10-03-05, 07:18 AM
I'm priming 80 year old plaster walls with Zinsser 123. I put the first coat on, and it's not on very even. It is, but there are some areas where you can see the wall underneath slightly, etc. Do I need to add a second coat of primer so that the wall is completely evenly covered? I'm not talking about big holes where I completly missed with the primer, just small areas where it didn't go on very thickly.
Old 10-03-05, 07:33 AM
Received 330 Votes on 293 Posts
Rarely is there ever a need to apply a 2nd coat of primer. As long as the wall has primer on it [as opposed to missed areas] there should be no need for another coat of primer. Unless there are stains showing through the primer it is ready for the top coat.
Old 10-03-05, 10:27 AM
marksr is right on the money Spooksmcgee
Unless you have "Holidays" (actual missed spots), or bad stains bleeding through (you'll need a sealer for those), you should be fine
The primer isn't supposed to look like a white top coat
Old 10-03-05, 01:50 PM
Received 94 Votes on 83 Posts
I have gathered from your post that the problem might be the wall itself - primer is not going to cover up for a wall that needs work, as 80 year old walls often do. If that's not the case and you just don't like the way the primer looked compared to a finished product, then the above posts are right on the money.
